Bazı Laptoplar için bios reset
Toshiba Bios Password Deletion
Satellite P100 & Satellite Pro P100
With notebook turned off;
Open Wi-Fi Cover
Remove Mini Card Wi-Fi card
Locate & Short Out JP8 for 5 Seconds
Remove short and turn on
NO BOOT
Press & Hold Power button to turn off
Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
Open Wi-Fi Cover
Locate & Short Out JP1 for 15 Seconds
(Satellite L10)
Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
Open Memory Cover
Remove Memory
Remove Black plastic insulation
Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
The jumper is always located under or near the memory modules
Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
Remove Strip cover
Remove 2 x K/B screws
Move K/B Unit up but don’t disconnect
Release & Remove Mini Card Wi-Fi Card
Locate & short C88 Pin 1 & 2 together
Power on Machine while still shorting Pin 1 & 2
As soon as the TOSHIBA logo appears, remove short
If machine boots, Password has been removed
Satellite A100 (PSAA2A-02C01N)
Remove Memory Cover from base of machine
Release & remove right side Memory Module
Lift black plastic insulation
Locate & short PAD500 Pin 1 & 2 together
Power on machine while still shorting Pin 1 & 2
If machine boots, password has been removed
TECRA A4 & Satellite M40
Open modem & Wi-Fi card cover
Remove mini PCI Wi-Fi card
Lift up black plastic
Locate & short C738 Pin 1 & 2 together
TECRA S1
Open palm rest cover
Locate & short C5071 Pin 1 & 2 together
TE 2300
Remove 2 x B12 screws from bottom of system
Remove strip cover
Remove keyboard screws 1 x B2.5 & 1 x SF4
Remove 1 x 4mm screw & Wi-Fi cover
Remove mini PCI Wi-Fi card if fitted
Locate & short points as shown in picture below
Power on machine while still shorting points
Short for 5 seconds
Nothing will appear on the screen
Turn system off holding down power button
Password is now removed
Satellite A60
Open Wi-Fi slot cover
Locate & short C561 Pin 1 & 2 together
If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
Geçen sene kurulması gereken bios şifreli bir notebook vardı. Kurulumu başlatmak için yapılan bios boot ayarlarına giremiyordum 2 gün kafayı yedim :] servis şifre kırmak için 100$ para istiyordu, bende dayanamadım notebooku açtım içindeki bios pili manuel baypass ettim :] sorunu çözdüm.
Not:Yeni model notebook anakartlarında bios direkt gömülü geliyor.
evvet.. bizde benzer bir sorundan müzdaripken bu bilgiler hayat kurtardı :]
aaaaaaa burada kameramı var :hö: :hö: :hö:
Başkanım bende HP NC 8430 Notebook bios şifresini kırmaya çalışıyorum ne yaptıysam olmadı:kızgın:
Pilini çıkardım bataryayı da çıkardım kısa devre yaptım saatlerdir bekliyor böyle ama yine şifre istiyor, zaman bulupta interneti araştıramıyorum. :.(
Son çare olarak sıcak su ve çamaşır suyu ile temizcce yıkayacağım :P
bios şifresi mi, windows login ekranı ise bu yöntemler işe yaramaz Hamit :P
bios pilini çıkartırken notebook 'a adaptör takılı değil ve Bataryası da çıkmış durumdaydı dimi ?
Evet bios şifresi malesef;
Adaptör çıkmış durumdaydı, heryri kısa devre ettim artık gözümü karartıp :]
peki batarya yı çıkarttın mı?
Sizinle konuştuktan sonra çözüme ulaştım :]
Hp Notebookların bir bölümünde bios şifre resetleme şu şekilde;
Bios pili çıkarıyoruz, batarya çıkaryoruz ve adaptör bağlı değil (Pc'de enerji yok)
5 Dakika bekledikten sonra (isteğe bağlı baypas yapılabilir):kızgın:
Önce Bios pilini takıyoruz, batarya takmadan adaptörden enerji veriyor ve Pc'yi açıyoruz
Bios ayarlarına giriyor (bu aşamada şifre artık sormuyor) ve birkereye mahsus kaydediyoruz,
İşte bu kadar, kolay gelsin...:tamam:
Son Mesaj Yazar: Glt.Özt
02-18-2015, 09:23 PM
Son Mesaj Yazar: doctor
01-12-2015, 10:20 PM
Son Mesaj Yazar: yolcu02
05-09-2014, 07:52 AM
Son Mesaj Yazar: Spike
02-12-2013, 03:24 PM
Son Mesaj Yazar: MuratD
01-24-2013, 02:30 PM
