02.02.2011, 10:18
Toshiba Bios Password Deletion
Satellite P100 & Satellite Pro P100
With notebook turned off;
Open Wi-Fi Cover
Remove Mini Card Wi-Fi card
Locate & Short Out JP8 for 5 Seconds
Remove short and turn on
NO BOOT
Press & Hold Power button to turn off
Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
Open Wi-Fi Cover
Locate & Short Out JP1 for 15 Seconds
(Satellite L10)
Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
Open Memory Cover
Remove Memory
Remove Black plastic insulation
Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
The jumper is always located under or near the memory modules
Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
Remove Strip cover
Remove 2 x K/B screws
Move K/B Unit up but don’t disconnect
Release & Remove Mini Card Wi-Fi Card
Locate & short C88 Pin 1 & 2 together
Power on Machine while still shorting Pin 1 & 2
As soon as the TOSHIBA logo appears, remove short
If machine boots, Password has been removed
Satellite A100 (PSAA2A-02C01N)
Remove Memory Cover from base of machine
Release & remove right side Memory Module
Lift black plastic insulation
Locate & short PAD500 Pin 1 & 2 together
Power on machine while still shorting Pin 1 & 2
If machine boots, password has been removed
TECRA A4 & Satellite M40
Open modem & Wi-Fi card cover
Remove mini PCI Wi-Fi card
Lift up black plastic
Locate & short C738 Pin 1 & 2 together
TECRA S1
Open palm rest cover
Locate & short C5071 Pin 1 & 2 together
TE 2300
Remove 2 x B12 screws from bottom of system
Remove strip cover
Remove keyboard screws 1 x B2.5 & 1 x SF4
Remove 1 x 4mm screw & Wi-Fi cover
Remove mini PCI Wi-Fi card if fitted
Locate & short points as shown in picture below
Power on machine while still shorting points
Short for 5 seconds
Nothing will appear on the screen
Turn system off holding down power button
Password is now removed
Satellite A60
Open Wi-Fi slot cover
Locate & short C561 Pin 1 & 2 together
If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
Open Wi-Fi Cover
NO BOOT
Open Wi-Fi Cover
(Satellite L10)
Open Memory Cover
Remove Memory
NOTE:
Tecra A3/S2, A5, A6
Remove Strip cover
TECRA S1
TE 2300
Remove strip cover
Short for 5 seconds
Satellite A60
